Login Error
Close
Standing Seam Steel Roof vs Corrugated Steel Roof
by DoItYourself Staff
If you want to add a new top layer to your roof, you might be considering either the standing seam steel roof, or perhaps a corrugated metal roof. The differences are not only in the appearance of the roof, but also in the durability and security of the roof. This can seriously affect the choices that you make when looking at standing seam steel roof or corrugated metal roofing.
The Standing Seam Steel Roof
The standing seam roof is considered to be one of the best ways to protect your roof. It is by far the longer-lasting of the metal roofs available, and you may find that insurers look favorably upon the roof due to its stability and strength. With the standing seam, you conceal the fasteners, which helps to avoid water getting into the seam and then into the fastener hole, leading to leaks. On the downside, the standing seam steel roof is much more expensive to install than the corrugated metal.
Corrugated Metal Roofing
This type of roofing material is cheaper and many people will choose to have it fitted for this reason. The metal itself is not as durable, but you can prolong its life by painting the surface with acrylic roof paint, and by using long-life fasteners, which will help to prevent leaks.
 forum activity
