Login Error
Close
Steam Room Maintenance
by DoItYourself Staff
Your steam room can be a breeding ground for bacteria. The mechanisms that create the heat and steam will also need routine checking and maintenance. If you keep up with the care of your sauna, you can reap the healthful benefits for a long time.
Cleaning Steam Rooms
Clean your steam room from top to bottom with an antibacterial cleanser. Depending on which material your steam room is constructed from, these cleaners may vary. Check with the manufacturer to find out which cleanser you should use.
Caring for Steam Mechanisms
Also take care of the steam mechanism. Drain the steam generator regularly because grime and bacteria can build up there. Then it will disperse into the air and make the steam room unhealthy for you.
Repairing Cracks
Keep an eye on any cracks in the joints of your steam room. If you find any cracks, seal them firmly with silicone sealant. This sealant will prevent exterior moisture. Keeping your steam room fully enclosed and sealed allows optimal usage and cuts down on deterioration. If you care properly for your steam room, you should be able to use it as often as you wish, for as long as you want.
 forum activity
