Login Error
Close
Steam Shower vs Sauna
by DoItYourself Staff
One type of self-pampering that is a favorite among fitness enthusiasts is going for a steam shower sauna. This form of healthy relaxation is best done after a tiring day to rejuvenate the body and calm the mind. Both the steam shower and sauna uses heat to create their relaxing effects, albeit heat is produced differently by steam shower and sauna. Using the steam shower or the sauna is beneficial to the body in many ways. Below are the differences between the steam shower and the sauna.
What Is the Difference between a Steam Shower and Sauna?
The first difference between a steam shower and a sauna is the kind of heat used. A steam shower or room operates on wet heat. Wet heat for the steam shower is produced from generator or by pouring water on hot rocks. The body exposed to the high temperature of around 100 to 120 degrees F and humidity will give way to sweating that will aid in weight loss. Gyms and spas offer steam shower rooms equipped with fragrances added to further give a relaxing mood to the rooms. On the other hand, the sauna operates on dry heat. Saunas register low humidity. The temperature in a sauna is about 200 degrees F. It features two benches, a lower bench level and a higher bench level. The temperature on the higher bench escalates because heat rises.
What Benefits Do Steam Shower and Sauna Offer?
Steam shower is beneficial for those that have breathing problems like people with asthma or bronchitis. The humidity in the steam room will aid in breathing issues. By just staying still in a steam room, the steam created may recover breathing problems. The heat will cause the body to sweat more thereby cleaning the body of toxins through sweating. The benefit of the sauna is basically the same as the steam shower only that sauna temperature can escalate into higher temperatures than the temperature rise of a steam shower or room.
What are the Drawbacks of using the Steam Shower and the Sauna?
Since a steam room creates wet surroundings, this could pave way for a breeding ground of bacteria which is its greatest drawback. This drawback may be avoided when cleanliness in the area is well-maintained. It is therefore advisable to wear special foot pads when inside the steam room. The humid environment of a steam room and sauna may affect individuals who have active tuberculosis or acute arthritis. The drawback posted for the use of sauna is that sweating does not occur as much as when using the steam shower, leaving toxins in the body.
What is the Best Option between the Steam Shower and the Sauna?
The choice between steam shower and sauna comes down to personal preference. These two options both give relaxation to the body just by keeping still in the room. Both offer health benefits. The steam room is beneficial for those with breathing problems. The sauna helps in relaxing the body. Whatever choice is done, it is recommended that showers be taken before and after using the rooms to be cleaned of bacteria and other impurities.
 forum activity
