Steel Roofing Pros and Cons
Steel roofing offers several benefits over other roofs. It has long been used in the construction industry to produce some of the best and most durable roofs. Steel is one of the hardiest metals available and has several advantages. However, deciding what type of roof to have installed on your home requires careful consideration. It pays to take a look at the pros and cons of steel roofing. This will give you a good picture of what steel offers over other metals and materials such as slate, tiles, shakes or dried grass.
Durable
Steel roofs are among the most durable roofing types you will find on the market. Steel has a long history of reliability and resilience in building and construction. In most cases, they can last a lifetime, making it a sound investment.
Fire Resistant
Steel is fire resistant, which makes it a protective type of roof to have installed. During accidental fires, it can actually help contain the fire from extending too much to the rest of the house. You can end up saving considerable amounts in damages because of a steel roof.
Withstands Strong Winds
The tough properties of steel guarantees that it will stand up to strong winds and storms. This is especially worth noting if you live in an area where strong winds are a common occurrence. With a steel roof, you can be more confident that your house will stand during adverse weather.
Versatile
Steel roofs are versatile and offer you much more flexibility when it comes to color, design and style. You can easily change the color of your roof without having to replace the entire roof simply by painting. A steel roof can be produced to look like other roofing materials, yet give you the outstanding properties of steel material which is hard to match. Besides, it is possible to install a steel roof over an existing roof, which helps to reinforce your roof and adds to the value of your home.
Environmental Benefits
Steel roofing consists of more than 50% recyclable material and makes an envronmentally sound choice. There is less pollution of the environment and landfills associated with a steel roof.
Cons of Steel Roofs
Steel roofing costs considerably more to install than other roofing materials. It is also a complex type of roof to install and one that requires professionals to do the job. This adds up to the overall costs you'd have to meet should you opt for a steel roof. You must also contend with a fair amount of noise if you install steel roofing. During hailstorms or heavy rainfall, you will be subjected to much noise generated on the roof which can be quite a nuisance. You may have to install some sheaths underneath your steel roof to reduce the incidence of noise. Again, this would add to the overall costs of having a steel roof.
