Steel Sliding Door Hardware: What You'll Need
Your steel sliding door will require a different type of hardware than the typical wood door. There is a reason why there are wood screws and metal screws for the various materials that you can use in your home projects. When installing a steel sliding door in your home or garage, make sure that you have the correct hardware to complete the job.
Metal Screws vs Wood Screws
A metal screw can be used on wood because it has much sharper threads to remove the burrs that occur on metal. Wood screws should not be used on metal material though.
Make sure that you have the right materials when you are working with your steel sliding door so that it is fastened securely.
Added Protection of Steel
Steel provides a much more durable door than other materials. It wears well and can be counted on to last for many years. The look of steel can be made very decorative and attractive with some imagination and creativity.
You should plan out the design of your steel doors in advance so that you can create the right look for your home or garage. These doors are also a great look on a commercial building as well.
