Login Error
Close
Stick-Build
by DoItYourself Staff
Stick-Build is a term usually used by construction crews to refer to the process of building a structure from the ground up on site using conventional building techniques.
Advantages and Disadvantages to the Stick-Build Method
There are a number of advantages to the stick-build method of building a structure. Building a structure in this method will usually lead to a more custom structure, and slight changes in the overall layout of certain aspects of the structure be made when requested. Adjustments which may become necessary to meet site tolerances can be made.
The major disadvantages to it are related to time, cost, and quality control. Panel construction is the main alternative to the stick-build method. Panel construction is generally faster than the stick-build method, as the sections such as the sub-frames, floor panels, and roof trusses are all built in a factory and then simply installed on site. The fact that they are built in a factory also lends itself to a generally higher and more consistent level of quality control than what is achieved with structures built using the stick-build method.
 forum activity
