Login Error
Close
Stone Vinyl Siding
by DoItYourself Staff
Stone vinyl siding is a type of vinyl siding that contains a stone facade that is laid over the vinyl. This gives the siding a stone appearance that is similar to that of actual stone siding. Using stone vinyl siding to imitate the look of a stone sided home helps a builder or homeowner save on the cost of this installation. This cost savings between stone vinyl siding and stone siding can be up to 300 to 400%.
Cost Comparisons for Stone Vinyl Siding
Vinyl siding is a less expensive building material that is typically found in mid priced new home constructions of between $250,000 and $300,000. Vinyl siding can also be used in renovation projects of the home owner. Vinyl siding typically costs around $88 per square while comparable stone siding can run between $350 to $450 a square. This difference alone gives strong consideration for the use of stone vinyl siding over stone siding.
Installing Stone Vinyl Siding
Stone vinyl siding can be installed more easily than stone siding can and makes it an easier material for a builder or building contractor to work with. If you are looking to achieve  the look of stone without the cost, you should buy stone vinyl siding for your home.
 forum activity
