Login Error
Close
Strawberries: Transplanting Tips
by DoItYourself Staff
what you'll need
  • Landscape Fabric
  • Utility Knife
  • Strawberry Transplants
  • Organic Mulch
  • Hand Spade or Garden Trowel
  • Bucket
  • Water
  • Fertilizer
  • Measuring Cup
  • Pruning Shears
By and large, transplanting strawberry seedlings and existing strawberry patches is a fairly simple process, not so different from most other fruit and vegetable transplanting. Follow the steps below, and you can easily transplant your strawberries to a new location outside.
Step 1 - When and Where to Plant
Strawberries are best planted in well drained soil, preferably in a raised bed to increase drainage. The soil should be enriched with organic mulch or other organic matter. To do this, simply add a two to three inch layer of organic mulch on top of the garden and till the soil up to about a foot deep. You can do this by hand with a spade or garden trowel, or with motorized equipment if available.
If you are transplanting an established strawberry patch, do so in the early fall so that the roots have a chance to establish themselves before the plant goes dormant for the winter. For new plants, do your transplanting in the early spring, after the last frost.
Step 2 – Adding Landscape Fabric
While not crucial for healthy plants, laying down landscape fabric has become a stable of many garden fruits and vegetables. It will help keep the ground moist without needing to over water them. Cut your fabric to lie across the entire garden. If necessary, cut several pieces and overlap them a bit.
Once in place, start cutting X’s in the fabric, just big enough for the root balls of your strawberries. Obviously you’re going to cut bigger if transplanting established strawberry patches, as opposed to new seedlings. Be sure to leave between 8 inches to a foot between the holes, depending on the type of strawberries your are planting.
Step 3 – Digging and Fertilizing
Tuck the cut X’s underneath the fabric, and dig out a hole deep enough for your root ball. Mix an all purpose fertilizer for fruits and vegetables according to the instructions on the fertilizer. Use the measuring cup to pour about half a cup of fertilizer in each hole just prior to transplanting.
Step 4 – Planting
For transplanting seedlings, do so just like any other new fruit or vegetable plant. Cup the soil from your pot with the stem between your fingers, and turn it upside down. Tap the bottom and/or squeeze it gently until the plant slides out. Then, place it in the soil at the same depth as it was before, packing the soil in gently with your fingers to eliminate air pockets, and unfold the loose flaps of your fabric.
For established strawberry patches, try to keep as many of the roots intact as you can. For any broken roots, make a clean cut on them with pruning shears. If excess dirt coats the roots, soak them in a bucket of water until the dirt is loose and falls off, then gently fold the roots into your root ball and plant. Pack the soil in gently with your fingers.
Step 5 – Mulch
Cover your strawberry patch with loose mulch, such as clean straw, dried leaves, or peat moss. Don’t use green grass clippings, as they tend to mold and compress the landscaping fabric, reducing air circulation, and can cause fungus growth.
For more specific information, contact a local nursery about your particular type of strawberry plants.
 forum activity
