Stripping Wallpaper with Fabric Softener
what you'll need
- Fabric softener
- Water
- Container
- Sponge
- Putty knife
- Paint roller
- Neutralizing solution
Stripping wallpaper off the wall is not a very difficult task. However, wallpaper in old houses does not strip off easily and can be laborious. Moreover, if not removed properly, its glue can be left sticking on the walls. This article explains how to remove wallpaper adhesive effectively with the help of fabric softener.
Step 1: Prime the Wallpaper
Prime the wallpaper. Use a utility knife to score the wallpaper and make cuts in the top layer of the paper. Wipe the walls with a sponge dipped in hot water. The heat from the water will soften the adhesive. Repeat the hot water treatment until the wallpaper peels away. Use a putty knife to remove as much wallpaper as possible.
Step 2: Using Fabric Softener
In a container of warm water, add some fabric softener. Apply this mix on the wallpaper with a sponge. Allow the mixture to sit for 30 minutes.
Step 3: Final Scraping and Cleaning
Use the putty knife to scrape off remaining wallpaper and glue. Wipe the wall using a neutralizing compound solution before the application of the new wallpaper.
