Login Error
Close
Suggestions for Cleaning Linoleum Floor Tiles
by DoItYourself Staff
Following specific tips for cleaning linoleum floor tiles can help maintain their appearance and longevity. Consistency is the key to keeping the floor looking like new. When selecting products, keep in mind that a cleaner with excessive pH will damage the linoleum. Here are few more suggestions to help keep your linoleum floor tiles looking great.
Daily Care
The best approach is to sweep the floor to remove all dust and other particles. Daily sweeping will help maintain your linoleum floor and reduce the amount of cleaning required in the future.
Cleaning
The best of suggestions for cleaning linoleum floor tiles is to use vinegar, which has a slightly acidic (low pH) composition. There is no need to dilute vinegar for cleaning your linoleum floor. Pour vinegar into either a bucket or a large bowl. Depending on how dirty the floor is, you may want to only use small amounts at a time. When the floor is exceptionally dirty, putting the rag back into the clean vinegar will result in only wiping the dirt with dirty vinegar. You should rinse the rag clean before dipping it back into the vinegar. Either way, wring the rag until it is damp with vinegar, and go wipe the floor. You may find that you need to go over the floor several times to remove all dirt.
There is no need to rinse your floor; it will dry perfectly clear. Alternatively, place the vinegar in a spray bottle and spray directly onto the floor. Dry with rags or paper towels.
Removing Difficult Spots
For stubborn spots, use a paste made from baking soda and water. With a clean rag, rub the paste onto the spot. Rinse with clear water.
 forum activity
