Login Error
Close
Sump Pump Installation In 7 Steps
by DoItYourself Staff
A sump pump is use to remove water from basements and comes in several types. Make sure that you select the ideal type for your situation and read the owners manual carefully. To install a sump pump, follow these steps.
Step 1 – Disconnect Power
Make sure the pump is not connected to the power supply.
Step 2 – Place Pump
Clean out the pit and place the pump inside preferably on a solid base so dirt would get in and block it.
Step 3 – Position Pump
Make sure the pump will not come into contact with the sides of the pit.
Step 4 – Connect Pump to Drains
Connect the pump discharge into the house drainage system using a non return valve to prevent any back flow.
Step 5 – Relief Hole
Drill a relief hole in the discharge pipe to prevent air locks.
Step 6 – Pump Cord
Fix the pump cord to the discharge pipe.
Step 7 – Reconnect and Test
Connect the sump pump to the power and run water into the sump to test it – You will need to fill the sump to the level that normally causes the pump to activate – on no account run the pump without water. It will rapidly overheat and seize up.
To reduce the risk of smells from the sump a pit cover could be fitted.
 forum activity
