Super Energy Saver Wall Insulation Materials
There are super energy saver wall insulation materials that are available for your home and home construction projects. Insulation, which is measured in what is referred to as its R-value, should be installed to meet the energy saving requirements for the area of the country in which you live. These standards are set by the Department of Energy (DOE) and specific R-value information is available at the DOE website.
Insulation is made from a variety of material. The super energy saver wall insulation materials should meet minimum insulation requirements and provide your home with the protection that it needs from weather, and in some cases, noise. This article discusses some of the super energy saver wall insulation materials to consider.
Rolls and Batting
The DOE recommend materials such as rolls and batting, which is a fancy way of saying an insulation blanket. These products are made from fibrous materials such as wool and fiberglass and are known for their super insulating properties and flexibility. They are built to be used for insulating the spacing between wall studs, floor and attic joists.
Batting and rolls have different R-values depending the type of wall that is being insulated. 2x4 stud walls usually contain wall batting that has an R-value of R-13 or R-15. 2x6 stud walls can use a batting that has an R-value of R-19 or R-21.
Loose-Fill Insulation Material
In addition to rolls and batting, loose-fill insulation material that can be blown into spaces with special equipment provides another super energy saver wall insulation. The material used in loose-fill insulation includes fibers or fiber pellets from fiberglass, rock wool or cellulose. The material is especially useful as an energy saver insulator in areas of the home that would be otherwise difficult to insulate. This would be high ceiling walls, tight enclosures and walls with extreme corners.
Rigid Foam Insulation
For areas of the country that require a higher R-value insulation, rigid foam insulation is another super energy saver wall insulation that is used. The material is effective where space is a consideration and provides R-values of 4 to 6-1/2 for every inch of thickness to twice the insulation factor of other insulating materials of comparable thickness.
The DOE provides exact information and installation tips for the various types of materials that are recommended for use in wall insulation. The tips provided focus on the considerations that must be taken into account when using wall insulation and the types of materials that provide the most energy saving. Higher R-values will be needed in colder climate states and increased flexibility for certain non-traditional constructions. The materials that you choose to use in your home to increase energy saving should be based on its insulating factor (R-value) and ease of use, not its cost or that it is cheaper than other materials.
