Terracotta Floor: Pros and Cons Terracotta Floor: Pros and Cons
Terracotta floor is known for its durability and earthy appeal. Terracotta, literally 'cooked earth,' is a ceramic that is manufactured by firing refined clay mixtures at high temperatures in kilns. Terracotta has been in use in a variety of industries for many centuries. Some of the main pros and cons of terracotta flooring are detailed below.
Durability
The biggest advantage of terracotta floors is their toughness. These floors can last for ages when they are manufactured and installed in keeping with quality standards. Several ancient sculptures and structures are proof of this long lasting quality of terracotta. Most terracotta flooring is available in earthy shades of red and brown. This reflects the natural color of the material, which is well liked for its earthiness and beauty. Terracotta flooring provides an old-worldly feel and ambiance to a home.
Versatility
Terracotta is one of the few materials that are suitable for both indoor and outdoor use. Its strength and beauty have made it useful in several scenarios and settings in architecture. Terracotta flooring provides a rustic look that is hard to imitate. It can be used sealed or unsealed, depending on the application and intended look. When sealed, terracotta is improved further in quality and will hold up to stains, moisture and scratches. Terracotta flooring is available in several shapes, sizes and patterns. You can choose from contemporary designs or traditional ones, depending on the setting and the look you want to achieve.
Compared to other ceramic materials, terracotta floors are not as cold. This makes them much more inviting and comfortable to walk on. The toughness of the material makes it ideal for use on driveways and patios. It is resistant to mold, fungus and bacterial growth as well. For all these advantages, terracotta flooring is still quite affordable.
Disadvantages of Terracotta Floors
Each terracotta tile tends to be unique and different in shade and color. This may not appeal to all consumers. Also, the quality and longevity of terracotta tiles is very difficult to deduce. This is because there are several varieties of the tiles being manufactured, all of which look reasonably hardy to begin with. However, lower quality tiles will begin to deteriorate within a few years of use.
Though terracotta flooring can be used without sealing, it will not last as long as tiles that are properly sealed. The material is very porous and can absorb moisture quickly. It can also crack and deteriorate quickly if left unsealed. Also, the material can quickly absorb stains if not protected properly. Such issues are difficult to repair and will usually require replacements, in which case matching tiles are difficult to find. For long lasting terracotta flooring, proper sealing is a must.
Installation of terracotta flooring can be quite tedious and complex. Unlike other flooring materials, terracotta tiles require professional installation and sealing. This often adds considerably to the overall expense. Though terracotta flooring is easy to clean, the grout is often discolored easily and requires some regular intensive cleaning.
