Login Error
Close
The Advantages of an Ethanol Fireplace
by DoItYourself Staff
The ethanol fireplace is a state-of-the-art invention that not only provides the warmth and coziness of traditional fireplaces but also has a number of very important advantages. Some of the innovations, described below, make the ethanol fireplace the preferred heating unit for homes and offices alike.
The Eco-Friendly Ethanol Fuel
Ethanol (or ethyl alcohol) is a substance which is produced from plants such as corn, switch grass, and sugarcane. It contains and emits virtually no carbon dioxide (CO2), a fact that makes it particularly environmentally friendly. To be precise, ethanol releases a modicum of CO2 due to the plants’ absorption of the gas, but it isn’t proportionally higher than the amount contained in human breath. The CO2 emitted by burnt ethanol is nowhere near the quantity released by petroleum-based fuels.
Moreover, ethanol does not produce any hazardous emissions that threaten human health and you will be guaranteed to have high room air quality. For this reason, the ethanol fireplace is an excellent choice for urban apartment dwellers who do not have immediate access to fresh air ventilation.
Flexible Design
Because ethanol fuel does not release harmful emissions, ethanol fireplaces do not require a chimney, flue or any other stationary outlet. They are available in all sorts of designs and sizes from walled-in fires with a protective glass panel to portable, spherical fireplaces, and living room glass tables with inbuilt fires (the latter option looks so exciting that it has to be seen to believe it). Overall, the variety of ethanol fireplaces is large enough to meet the requirements of even the most fastidious individual.
An additional advantage of ethanol fireplaces is that many of them come with a remote control, which allows the customer to automatically light or shut down the flames as well as to regulate their length and the heat they produce.
Unlike old-fashioned burners, ethanol fireplaces do not need any coals or wood logs, a fact which makes them exceptionally clean and easy to maintain. Usually, all you’ll have to do is supply the burning chamber of the fireplace with enough fuel.
Favorable Installation and Operational Costs
The portable ethanol fireplaces do not need to be installed and the walled-in fireplaces do not require a chimney or any other housing. This is why they necessitate a much smaller initial investment than masonry fireplaces. Moreover, since ethanol fireplaces do not require an outdoor outlet, they contribute to the better conservation of produced heat which often gets locked inside the room. By installing an ethanol fireplace, you will be paying for less fuel than you would for other types of fireplaces.
Furthermore, with an ethanol fireplace, there is no need to chop tons of expensive wood, burn air-poisoning coals, or call a professional to free that hapless raccoon stuck inside the flue. As already mentioned, the maintenance and operation of an ethanol fireplace is a much simpler affair. You need only buy fuel, tank up the burner, and feel the warmth.
 forum activity
