The Average Cost of Refacing Kitchen Cabinets
When a new look to your kitchen is required, you will find that refacing kitchen cabinets is less costly than a complete refurbishment. Understanding the average cost of the process will help you to decide whether it is a worthwhile option for your purposes.
Materials
The type of materials needed for refacing kitchen cabinets will dictate the cost, in addition to the number of cabinets to be worked on. Thermofoil or laminate can cost around $1000 - $3000, while wood veneer can cost up to $5000 at a basic level. The tools required to undertake the project will increase the average cost.
Labor
In addition to the cost of the materials for refacing kitchen cabinets, it is also necessary to consider the cost of labor. If using a contractor, this can run to several hundred dollars, depending on their experience and the length of the project. However, you will also find that do it yourself kits are available in the market.
Hardware
In the event that you intend to replace any of the hardware as part of the process for refacing kitchen cabinets, the cost of this will need to be taken into account. The cost of items, such as hinges and handles, will vary greatly depending on the type sought. However, basic varieties will run to only a few dollars.
