The Basics of Home Beer Brewing
Home beer brewing involves mixing together several ingredients and fermenting it to create beer. It also involves acquiring basic equipment and recipes. Equipment and recipes can be obtained from a local store or an online store. Here are some things to consider.
Basic Home Brewing Equipment
The process requires a pot for boiling the beer ingredients. It can be any pot large enough to be filled with the volume of beer to be produced (5 gallons recommended). The pot should at least be slightly larger to ensure that the ingredients do not overflow during boiling. Stainless steel pots are ideal, but any pot can do during the initial stages.
Two plastic buckets are also important for the fermentation process. Each has to be at least 5 US gallons in capacity, with a tight lid, and should be made from food grade plastic. In addition, an airlock is required to allow fermentation gases to escape from the vessel while keeping outside air away.
Additional equipment include sanitizers (chlorine, iodophor, or acid sanitizers), vinyl tubing for liquid transfer, spigot for beer transfer, bottles, bottle caps, bottle wand for filling bottles with beer, and bottle capper.
Basic Home Brewing Ingredients
The ingredients needed for the brewing process include the malt extract, water, hops (3 types), and yeast. The extract can either come in a liquid or powdered form. This is simply a form of concentrated malt that forms the main ingredient in beer brewing.
The water has to be clean enough for drinking, should not have any unpleasant flavor or smell, and should be sanitized in any way possible. The hops are plant buds that give the resulting beer its distinct aroma and bitter flavor. It also preserves the final product to protect it from spoiling. The brewer’s yeast is what makes the malt ferment. It is best to stick to brewer’s yeast as a beginner and probably experiment with bread yeast some time after.
Basic Home Brewing Procedures
Fill the pot with around 5.5 gallons water and heat it on top of a stove. When it boils, add the recommended amount of malt extract and keep stirring until the extract is submerged in the water. Stir constantly to avoid burning the malt on the bottom of the pot. If the liquid starts to boil over, lower the flame a bit.
Start a 60 minute countdown timer and add the first hop ingredient on the first minute, the second after 45 minutes, and the aroma hop after 59 minutes. Turn off the flame after 60 minutes, cover the pot and wait for the solution to cool down to around 65 degrees F.
Transfer the liquid to the fermentation bucket, add yeast according to manufacturer’s instructions, put on the lid and attach the airlock. Place the container in a cool dark location and wait for one week. Transfer the liquid to the other bucket and mix a solution consisting of 2/3 cup corn sugar boiled in a quart of water. Bottle the beer and store the bottles away for a couple of weeks before chilling and consuming them.
