cancel
Job type :
Zip Code :
community forums
comments
The Benefits of Ceiling Mount Kits
Manufacturers produce several ceiling mount kits designed for your home entertainment and cable systems. They can be a convenient addition to any entertainment system.
Thin Screen Television Mounts
Because of their thin size, plasma and LCD televisions can be installed and enjoyed in many places.
By installing to concrete, a wood stud or an internal load bearing joist with a ceiling mount kit, thin televisions or monitors can be placed overhead in offices, bedrooms or entertainment centers. This is a great method for freeing wall and floor space, eliminating the need for a bulky entertainment system, and creating a clean look.
Projector Ceiling Mount Kits
Another popular electronic item to mount on the ceiling is a projector. A projector that makes use of a ceiling mount kit is a great addition to a media room at home or work. Benefits of these kits are that they keep a projector safely out the of the way so that it is not damaged and the projection is rarely interrupted. They also provides a professional looking display.
Ceiling Mounted Accessories
Other beneficial kits include those for mounting speakers and wires to the ceiling. These are beneficial because they provide more realistic sound by mounting speakers above,  behind and in front of the listener. The cable mounts allow the cables to be kept out of sight, leading to a neat appearance in the media room.
member comments
Related Articles
What Can a Wired Home Do?What Can a Wired Home Do?
What can a wired home do?... read more
X10 Home Automation Q and A - Part # 3X10 Home Automation Q and A - Part # 3
X10Home Automation Components and Wiring... read more
Building With Automation in MindBuilding With Automation in Mind
wired home, Wired Homes - What is a Wired Home and How Do I Build... read more
articles we like
How To Tint Your Own Car Windows
Tinting windows is not as easy as it looks. Even specialists find the process of... read more
Stack Effect
There are several constructed objects that can make the stack effect such as a stairwell,... read more
Quick and Simple Short Term LoansQuick and Simple Short Term Loans
When emergencies happen you need to deal with the situation even if you don't get... read more
sponsored articles of the day
diy centers
