Login Error
Close
The Benefits of Direct Vent Gas Fireplaces
by DoItYourself Staff
Direct vent gas fireplaces are the most popular fireplace option among many homeowners. These appliances use gas to produce heat and a flue to vent out combustion wastes. These fireplaces have become very popular across the country due to the convenience they afford the owner. By acquiring one, you escape the inconvenience of chopping wood or cleaning ashes in the firebox. Direct vent gas fireplaces utilize 2 types of vents, the rear vent and the top vent. The rear vent is vertical and attaches to the wall, while the top vent goes out through the ceiling.
Cost Savings
Having a direct vent gas fireplace is advantageous to the homeowner. The unit is assembled in the factory. You then fit it into a wooden frame. After completion, there is no difference in appearance between it and the conventional fireplace. The homeowner saves from not having to cater for a chimney in his construction costs. In addition, the flue is much smaller in diameter than the chimney.
Installation and Maintenance
Installing a direct vent gas fireplace is easy and cheap. The unit comes with the manufacturers instructions, which detail the installation process in a systematic manner. The unit is cheap to maintain. You avoid the routine of chopping wood and clearing ashes to get the fire going. The unit ignites instantly without much hassle. It has strong insulation. It presents no risk to other wooden material in the house. You can place it near your furniture or curtains without fear.
Fuel
Direct vent gas fireplaces use natural gas or propane. These fuel options are highly efficient. In addition, the use of sealed glass doors helps to keep combustion waste out of the room. This is unlike the conventional fireplaces where clearing of ashes is a routine activity. The heat generated from the firebox circulates to other rooms fast. If you wish, you may use a fan to circulate warm air in the room. This unit draws in air from outside the house and directs it into the house along with the combustion emissions.
High Efficiency
Direct vent gas fireplaces are very efficient in their operations. Studies indicate that up to 78% of the energy generated by the fireplace transforms into usable energy in the form of heat. This is highly commendable when compared with wood fire options, which lose as much as half of the heat generated. The ignition options are also very efficient. Gas fireplaces use electronic or direct spark ignition to light up the fireplace. Other models use a safety light. All you need are sufficient reserves of gas to operate the fireplace throughout the cold season. A generator is also available to cater for those times when electric power is unavailable.
Designs
There are many designs to choose from depending on your tastes and preferences. You may opt for one of the multifaceted designs or a custom made one.
Caution: If you intend to install the fireplace yourself, then you need to follow the manufacturer’s instructions very keenly for your own safety. You also need to adhere to the local building regulations as you install the unit.
 forum activity
