Login Error
Close
The Best Countertop For Your Bathroom Sink Vessel
by DoItYourself Staff
There are a wide variety of different countertop options for bathroom sink vessel installation. You should consider what the best counter top will be for your bathroom sink vessel. Here is some of what you need to know to ensure the proper installation for modern style bathroom sink vessels.
Step #1: Choose your Bathroom Sink Vessel
Before you can select the right countertop for your bathroom sink vessel, you are going to need to choose your vessel. Bathroom sink vessels come in a variety of different sizes, shapes, colors and styles. You are going to want your countertop to match all of these things as well as to be compatible in the way of hardware. Once you have chosen the right bathroom sink vessel, you can determine what type of countertop will be ideal to suit it.
Step #2: Weigh Countertop Options
The countertop that you choose for your bathroom sink vessel needs to be compatible in order for you to achieve the look that you are going for. Unlike most sinks where the sink is completely recessed into the counter, with a vessel sink, the sink is raised mostly if not completely out of the countertop. This means that a countertop that already has a sink hole cut in it will not work for your vessel sink, and you need to start with a completely in tact countertop.
Step #3: Consider Style Options
Choosing the best countertop for your vessel sink has more to do with it than just choosing a whole, finished sink counter to use. You are also going to want to match the color and the style of your countertop with your vessel and other elements in your bathroom as well in order to create a coordinated look.
Step #4: Consider Installation
Another consideration that needs to be addressed is the installation of your vessel sink, because it will impact the best countertop that you choose. Most vessel sinks do not come equipped with faucets, so you are going to want to choose a countertop that allows you to install your own faucets. You need to choose a countertop that works well with placing the faucets and the vessel sink, which may mean choosing a countertop that you can easily cut into and finish off for the best results.
Step #5: Consider Materials
The countertop that you choose can be made out of any material, but it must be finished and sealed because vessel bathroom sinks are capable of splashing. Your countertop should be waterproof and water resistant in order for it to best suit your bathroom space. Another consideration to make when it comes to the materials that your countertop is made out of is height, as some materials are higher than others, and if the countertop is too high then the sink's lip may be too high as well. Choosing thinner materials may be an option, but this may jeopardize the strength of the countertop in the process depending on what type of material you are dealing with.
 forum activity
