Login Error
Close
The Best Green Building Material for Building a Porch
by DoItYourself Staff
More homeowners nowadays prefer green building material for home installations. This reflects on the increasing concerns regarding climate change, environmental sustainability and personal health. Eco-friendly products are considered to be safer than most of the conventional construction materials. This is because they have fewer negative impacts on the environment. Energy efficiency and durability also help to determine to what extent a material can be considered as eco-friendly. If you’re about to build a porch, some of the eco-friendly options available to you are given below.
Bamboo
Bamboo has the fastest growth rate amongst hardwoods. This helps to easily replenish the species. You can use bamboo for the walls of your porch or to partition within, if desirable. Bamboo also has a very high tensile strength which makes it ideal for a porch floor. It is available in boards or in click and lock panels for floor purposes. Bamboo has an excellent resistance to moisture which helps to extend its longevity. It absorbs 4 times the carbon dioxide that most trees absorb. This helps to improve the quality of air in your home.
Cork
Cork is removed from the exterior of certain living trees at carefully spaced intervals. Usually, this is just once every 10 years. One tree produces hundreds of pounds of cork. Once the cork is harvested, the tree continues to grow. The technique yields a valuable green building product and helps to preserve trees at the same time. Cork is one of the most renewable wood products available. It can be used to create unique floors that easily reflect natural beauty. Cork panels can help you create a soft yet durable porch floor. Cork can also be used to construct porch walls. It is resistant to mold and pests which adds to its durability.
Linoleum
It bears a strong resemblance to vinyl. However, unlike the latter which is petroleum-based and contains chemicals, linoleum is made from organic sustainable materials. These include linseed oil, pine sawdust, pine rosin, powdered cork, limestone and color pigments. Linoleum is biodegradable which helps to sustain the environment. Although it costs about twice as much as vinyl, it lasts almost 5 times longer. You may want to consider a linoleum floor for your porch.
Recycled Products
These include metal, plastic, glass, fiberglass, masonry products and heavy timber. You can use vinyl composite planks to construct the floor of your porch. Sometimes, a small proportion of wood is added during the manufacture process. You may want to use recycled metal, vinyl or fiberglass to construct your porch roof. The choice to use recycled content reduces the demand on environmental resources, many of which are already scarce. It also helps to reduce what ends up in landfills.
Reclaimed Materials
These materials are sourced from demolished buildings or discarded items. They include bricks, timber and metal. You may want to make use of old tires for the baseboards on your porch. For installation of porch steps, you may want to consider reclaimed bricks. Reclaimed materials usually come cheaper than newly manufactured building materials. However, they have a good quality. This helps to control your budget.
 forum activity
