Login Error
Close
The Best Home Recording Studio: Working with Small Spaces
by DoItYourself Staff
A home recording studio nowadays can be set up quite easily in one’s home. This is mainly due to the fact that several simple methods can enable one to soundproof a room without ending up bugging the relatives and neighbors. Besides, most recording equipment and devices required in a recording studio are now available at relatively lower costs and in smaller sizes, which make them more affordable and more easily set up in a normal room.
Determine What You Would Like to Include
First of all give some thought to what you would like to include in your home studio. You may have some priorities and would need to adjust according to them. Some home studios specialize on vocal recording mainly, while others record live bands. Consequently different needs will require different types of equipment, which will have a direct impact on the space required. So, make sure to start off by listing the equipment and accessories you feel are essential for your home studio. Then, check what is available on the market so as to see the prices, the ranges available and ultimately the size that each element will take up.
Determine the Space or Room You Will Use
Depending on the space you will need to take up, you can then have an idea of how large an area you will require to effectively set up your home studio. Rooms in a house are on average of the same size, so the chosen area must accommodate everything needed to set up your home studio. Apart from determining the minimum area you need, you also need to take into account other factors dealing with the location of the room. The room you choose should ideally not be too near bedrooms. Even though you will soundproof the home studio, some noise such as low humming, vibrations and similar sounds will still be heard in the nearby rooms. Hence, it is usually best to choose a basement, an attic or a room at the furthest end of the house. A garage would also be ideal.
Determine the Layout You Will Adopt
After having made a good research as to the various models and sizes available connected to  recording equipment and similar devices such as speakers, microphones and computers, you will then need to plan out the layout you will adopt in the space available. You need to ensure a good format which enables you to fit all the equipment in the best positions, while also allowing enough space for movement and other accessories such as a cupboard, table, chairs etc. Most importantly you need to make sure to allow enough room for musical instruments to fit well. Drums and synthesizers for example will take up quite some space. If you plan to do live band recording, you need to provide enough room for comfortable positioning to ensure good performances.
Soundproofing Measures and Other Related Decisions
Soundproofing is a crucial aspect. Some methods for soundproofing include attaching carpets and foam to the walls, attaching vinyl strips, changing apertures and similar measures. These may lessen the area of the room a bit further so you need to take these factors into account too.
By bearing in mind these aspects you can still set up a good and efficient recording studio even if the space available is a bit limited.
 forum activity
