Login Error
Close
The Best Tips for Installing Leviton Structured Wiring Systems
by DoItYourself Staff
Leviton structured wiring is a type of wiring system that is used in many residential and commercial structures. Structured wiring in defined as a wiring system installed in a home or business for distribution of telephone, video, audio and data signals. It is a bundle of cables that come together at your television, telephone or data port. It has 3 components: a distribution panel, high-performance cabling and multimedia outlets.
A distribution panels has two functions. One is that it terminates all of the service provider services such your telephone, cable television, cable modem and home security system. And two, it distributes those signals to those locations around the house. High-performance cabling signals sources form your home motion detectors or security cameras. This component is desirable because it futurizes your home for technology upgrades. And lastly, multimedia outlets provide handy plug-and-play points all around the home to provide the multimedia outlets for your telephone, digital audio, high-speed Internet, and everything else that you currently have and future devices that will be installed in your home. Here best tips for installing a Leviton structured wiring system.
Less Usage
Every connection additional connection degrades system performance, so if you could use less the better. A best example we can site is if a jack has so many connections on it, the full capability of a wire receiving signal will be lessened because signals have to go through a lot of other wiring.
Excess Capacity
It is best to provide excess capacity in terms of cable and outlets lack thereof. This may be contrary to the first tip but it is always better to have extra capacity acceptance so that when more is needed, it will be readily available.
Wiring
Wire to the highest expected data rate or speed or greater and never less. This will create slowness in signals needed and will be bothersome.
Quality and Origin of Components
Never add components of unknown or questionable origin and quality. At the very best, the system will transmit signals to the level of its weakest component. Every element and connection is important. Always use high-quality wiring as low quality can compromise other wirings.
Connections
Take note of all connections carefully and precisely. It is also important to keep all of your wiring installations neat and well organized. When the time comes that you need to modify or troubleshoot your system, it will be easier for you to assess the problem in the future.
Testing
Always test everything. A properly working structured wiring system only works well if everything from the beginning starts well. If wirings are not properly functioning, problems could arise at other points. Always function-test the wiring system.
 forum activity
