The Uses of Plastic Cladding
There are many uses for plastic cladding within the construction industry. Plastic cladding is simply a weatherproofing coat that applies to various different building materials. The most current, and popular, type of plastic cladding that is used is made from PVC, which is a clear plastic coating that is placed on the skeleton of the structure. The uses for plastic cladding are endless, but below are some of the most common.
Fascia Boards
Fascia boards are one of the most weather worn parts of a house. They are always in the weather, and they are located behind gutters which spill over, causing water damage. The fascia boards always receive the direct effects of any bad weather conditions that your area may experience.
Soffit Boards
Soffit boards are underneath the eaves of a house, and can get major water damage if the roofing materials begin leaking. As a normal rule, soffit boards are thin material that is attached in order to cover the eaves, but they are not very sturdy or water resident. Having soffit boards made out of plastic cladding is a great idea because it not only will add a nice look to the house, but supplies a sturdy weatherproofing material as well.
Internal and External Cladding
Plastic cladding can be substituted for any area in which you have cladding installed. Plastic is strong and versatile, so any application that calls for cladding should have plastic cladding instead of basic. For instance, interior bathroom walls seem to deteriorate quickly because of the constant steam and moisture. Adding plastic cladding to the walls will not only increase the life of them, but it will also allow you to be more comfortable in the room. When bathroom walls get wet they form mold and bacteria, which causes an odor that makes the entire room uncomfortable to be in.
Windows
As we all know, windows take a beating. Not only do they have to deal with direct contact to the weather, but they also have to deal with abuse from constant use. Moving windows up and down, or side to side, can slowly wear away the paint and caulking that was originally used to weatherproof them. Plastic cladding makes a great around the entire window, one that will hold up to abuse that they take on a daily basis.
Doors
Doors, especially the main front and back doors, take a beating, ten tens as much as a normal window. All outer doors have direct contact with the weather, which beats on them relentlessly. They also have to be stronger because they take a ton of abuse. You slam them open and closed, you kick them, you hang on them, and you even climb on them sometimes. It is important to have a weather tight seal around all your doors, and plastic cladding gives you a great alternative to paint, caulking, and weather seals.
Of course, this is only a partial list of the many uses that plastic cladding has. Basically, anything that takes abuse and has direct contact with the ever changing weather conditions can benefit from.
