Thermal Break Aluminum Windows: Pros and Cons
When choosing aluminum windows for your home, it is a good idea to look into the thermal break option. This option is available in the high end side of aluminum windows, but they provide much better insulative protection than normal aluminum windows. But should you install thermal break aluminum windows? Here are a few pros and cons to consider.
Do Not Need Heavy Maintenance
One of the great things about aluminum windows is that they have a baked on enamel that does not rust or fade. You do not need to maintain it as much as any other type of window. A basic cleaning in the spring and fall will suffice.
Better Insulative Properties
Aluminum windows are notoriously bad in letting out heat during the colder weather. This heat then forms into moisture droplets which coat the inside of the window. Ice forms and causes the window to crack or frost up. The thermal break separates the interior and exterior window panes for much better energy efficiency.
Cost Prohibitive
To get that thermal break the cost of the aluminum window will be increased more than other types of better insulated windows. While the cost be a little bit prohibitive in some budgets, the costs will be made back in the amount of energy that is saved through the thermal break windows.
