Three Keys for Maintaining a Steam Boiler
Using a steam boiler is an effective heating solution coming in a huge range of sizes serving the purpose of generating heat for big rooms or big houses. However, they need a lot of maintenance especially since they constantly creating steam to warm the air which is then pumped or circulated in your room. There are some important elements or keys which need consideration in order to maintain a steam boiler’s functionality.
1. Controllers of Heat
Two of the most important things in a steam boiler are the boiler drum level controller and the heat exchanger. These two elements need to be at optimal level for the best results and for utmost safety. The boiler drum level controller is extremely important because it is the controlling device that regulates the drum level when the boiler starts so as to keep a constant steam load. On the same level, the heat exchanger is an essential part of the steam boiler; it controls the heat exchange transfer rates from one fluid to another. Its functionality is imperative in order to maintain a balanced level of heat transfer. Moreover, the steam boiler has a thermal insulation layer which helps preserve the loss of heat and prevent the boiler from overheating while maintaining a proper surface temperature. Thus the maintenance of these parts of the steam boiler are a must in order to safeguard the functionality of the boiler and safety of the user.
2. Heat Pressure and Efficiency
To maintain a safe environment, steam boilers are equipped with pressure relief valves which are installed to safeguard and ensure the proper creation and exchange of steam in the boiler’s system. Moreover, steam boilers have incorporated gauges that measure the amount of water inside the boiler. Such gauges are meant to display the amount of pressure in the boiler, the water levels in the boiler and its limits. It is very important to keep an eye on these gauges and make the necessary changes and regulations in order to avoid an overload on the boiler’s system and to keep optimal efficiency and maximum safety. Furthermore, it is always important to make regular inspections and checks on the boiler for best maintenance safeguarding. In fact, these regular checks will help you prevent many maintenance issues if you always make sure that the boiler is functioning properly. De-scaling your boiler once a year and calibrating the gauge system are two of the key elements that come in with regards to maintenance of steam boilers.
3. Societies and Codes
If you are trying to maintain an already existing steam boiler in the household or in the building it is always important to take note of the above mentioned keys. However, if you are going to buy a new boiler it is very important to make sure that the boiler complies with ASME regulations (American Society of Mechanical Engineers) on boiler and pressure vessel codes. These codes regulate maintenance and inspections on boilers and thus it is preferable to buy a boiler which complies with such codes to avoid maintenance issues. Moreover, the AFUE (Annual Fuel Utilization Efficiency) codes help regulate the efficiency of boilers and provide very helpful information on how to optimize the efficiency levels of your boiler.
These are just a few keys for maintaining your steam boiler. However, if you cannot make these checks and regular inspections yourself it is always important to frequently call a professional to aid you in the process. Remember that boilers are constantly creating heat and thus if not maintained regularly can become very dangerous.
