Login Error
Close
Three Tips for Choosing a Water Softener System
by DoItYourself Staff
A water softener system is a must-have investment if your water supply consists mainly of hard water. In fact, hard water is the source of a range of frustrating and possibly consequential situations which you do not want to face. Bathroom fixtures may be damaged, common kitchen appliances will have a shorter life cycle and washed clothes will seem soiled if hard water is used continually. Therefore, installing a water softener system becomes essential to safeguard your household, since it gets rid of the high amounts of magnesium and calcium which constitute hard water, and turn your water supply into a safe one. However, before spending loads of money blindly, make sure you read these tips before making your choice.
1. Test Your Water
Before you actually start to look for vendors and consider prices, you should test your water to determine its hardness. It would be a waste of money to install a water softening system only to realize later that it was not really required. Thus, contact a qualified individual so he can issue a report on the status of your water. Apart from outlining your water’s hardness level, the report would be very useful in suggesting which type of system would be best suited for your needs.
2. Consider the Different Types
The type of water softening system you use depends on the kind of salt it employs. The straightforward option would be to use sodium chloride, but in this case there would still be salt left in the water, so it should be avoided by people who do not consume salt because of health issues. A more healthy solution would be to use evaporation salt, since it is highly soluble and does not leave too much residual salt in your water. As one would expect, this type of salt is more expensive, since it requires a process to be evaporated from sea water. A third option is to use potassium chloride, which again is more expensive than its sodium counterpart, but which is also less dangerous. Finally, you can opt for a magnetic water softener, which makes use of electromagnetism to soften your water. This kind of water softening system is, however, in decline and fewer and fewer people are choosing it.
3. Choose the Right Vendor
When choosing a water softener system for your home, a critical look at the vendors in this area is a must. The reputation of the vendor plays a very important part—it is never recommended to buy from an unfamiliar firm with a shady status, especially seeing as this is an investment. To ascertain the vendor’s reputation you should check whether he has been active in the market for a sound period of time—the longer, the better. Naturally, a good warranty clause is also very important, so try to find a vendor offering a good backup in case of trouble. Carry out a thorough market research before making a decision—there are plenty of vendors offering a wide range of prices.
A water softener system is sometimes a required investment, and should therefore be given the necessary consideration. Make sure you follow these tips before making your choice, since as with all other household investments, you have to make sure that you are making the right decision for you and your family.
 forum activity
