Login Error
Close
Three Tips for Choosing Water Softener Salt
by DoItYourself Staff
If you happen to have a hard water problem at home, you may need to know that water softener salt is the solution for this problem. Hard water refers to water when there is a lot of minerals in it, and water softener salt helps you clean the water of those minerals.
If you have hard water flowing through the pipes in your house, they are more likely to get clogged due to the mineral deposits in the pipes themselves. Another reason why hard water is a problem is because if you use it for washing purposes, soap cannot properly dissolve in it. Water softener salts are used to enhance the flow of water through the pipes. However, when you decide to purchase a water softener salt, there are some things you should keep in mind.
1 – Finding the Hardness Of the Water
First of all, you need to find out the abundance of minerals in the water. This is because every type of water softener salt depends on the hardness of the water. You can take a one-liter water sample and take it to be tested in a laboratory.
The sample needs to be tested to see how much minerals it has in it. It is also tested to check the presence of calcium and magnesium. More salt is required if the result is that the water in the sample is very hard. If this happens to you, make sure that you will use a water softener salt that is very rich in sodium chloride.
2 – Choosing The Water Softener Salt
There are three main types of salts that you can choose from: the solar salts, the rock salts and the evaporated salts. Make sure that you select the most soluble water softener salt. In this way, you will be able to clean your water reservoir more easily.
Solar water softener salts are formed in a natural process via evaporation. These salts can be sold in crystal or pellet forms, but they do not dissolve much. Rock softener salts do not cost a lot of money. However, they lack solubility like solar softener salts. On the other hand, evaporated water softener salts are the best and most soluble of the three types.
It is highly recommended that you use evaporated salts if you do not wish to clean your reservoir on a regular basis. Such salts consist of about 99 percent sodium chloride; this is the reason why they have a high solubility.
3 – Asking Other Residents In Your Neighborhood
Another good way to choose water softener salt is to ask your neighbors or other residents that live in your local area. You can ask them for information about the salts that they use in order to get rid of hard water from their reservoirs and pipes. The answers that they give you may may be very helpful.
Apart from choosing water softener salt, you must also keep in mind the type of water-softening appliance you have. Remember that if you have a setting that the tank regenerates itself after a set time has elapsed, you will need a lot of salt because the tank will be cleaned even if the salt was not completely used, and therefore the unused salt will be wasted.
 forum activity
