Tightening an Oil Drain Plug
what you'll need
- Socket Wrench
- Rag
When you change the oil, you have to remove the oil drain plug with a socket wrench. Changing the oil is a relatively easy project for any type of do-it-yourself mechanic. The hardest part of the entire process, is tightening the oil drain plug after the oil has been drained. There are some specific steps you should take, in order to make sure the oil drain plug is tightened properly, and the oil does not leak.
Step 1: Clean Oil from Area
Before you set the oil drain plug into the oil pan, you must make sure that the pan is free of any oil. Use a soft shop rag and wipe off any excess oil that is left over. Clean the threads on the oil drain plug as well, before tightening it in the oil pan.
Step 2: Finger Tighten Oil Drain Plug
It is important to start the oil drain plug with your fingers, so that you eliminate the possibility of cross threading the bolt. Continue to tighten it, until you can not turn it anymore.
Step 3: Tighten Plug with Socket
Place a socket onto the oil drain plug and continue tightening it until it is snug on the oil pan. Give it a few more 1/4 turns. Do not overtighten, or it will warp the threads.
