Login Error
Close
Tile Bathroom Floor Vs Linoleum
by DoItYourself Staff
Having a tile bathroom floor can offer several benefits. However, some people prefer linoleum in their bathrooms for various reasons. Here are a few things to consider about whether you should put tile or linoleum in your bathroom floor.
Durability
One of the big factors that you should consider for a bathroom floor is durability. Both options will present you with a very durable floor, but tile will last a little longer. It is hard and is not damaged easily. Linoleum can rip, under certain circumstances.
Comfort
When it comes to comfort underfoot, linoleum is going to be the better option. It is going to be warmer and softer than a tile floor would be. It also will provide you with a level surface, whereas tile will be uneven because of the grout joints.
Cleaning
Cleaning the bathroom floor is something else that you will want to consider. When you have a linoleum bathroom floor, you should be able to mop it easily. You can thoroughly clean it. With a tile floor, you will have to worry about grout joints, which makes it a little tougher to clean. Dirt can be trapped down in the gaps and cause problems. The grout can also be stained by a number of different things.
 forum activity
