Login Error
Close
Tile Caulk Cleaning and Whitening
by DoItYourself Staff
what you'll need
  • Household bleach or bleach pen (grout and caulk repair pens)
  • Old toothbrush
  • Baking soda
  • Bowl or bucket
  • White vinegar
  • Rubber gloves
  • Sponge
Tile caulk is a rubbery material that is used to line the area between tiles and the edges of a bath or sink. Due to its frequent contact with water, the caulk can become moldy and discolored, giving your bathroom an unpleasant and dirty look.
Depending on the level of dirt and mildew on the tile caulk, you may be able to make it white again with ease.
Step 1 - Assess the Situation
To determine whether the caulk can be successfully removed by the following methods, you need to work out whether the mildew is on the caulk or beneath it. If the mildew appears to be beneath the caulk then you will need to remove it and replace it with a new one. If the stains are ON the caulk, then simple cleaning should get rid of them.
Step 2 - Paste
Applying a paste of baking soda and vinegar will help to break down the stains residing on your caulk. Mix 1 part baking soda to 3 parts vinegar in a bowl or bucket to make a paste. Apply the paste to the caulk, scrubbing gently into the stains with a toothbrush. Let the paste dry before moving on to the next step.
Step 3 - Bleach
Applying bleach solution to the caulk should kill the mildew growing on it. Put on your rubber gloves to protect your hands before mixing 1/4 cup of bleach with 1 gallon of water. Remember to open the bathroom window or switch on the extractor fan to help aid ventilation. This is necessary to prevent the inhalation of toxic fumes. Apply the bleach and water solution to the caulk generously, using a sponge. Leave the solution on the caulk for around 10 minutes for maximum effect.
Step 4 - Scrubbing
Scrub stubborn stains off of the caulk with an old toothbrush. Try to do this gently or you might actually scrub the caulk off. Rinse the bleach and water solution off the caulk with warm water. If you're not happy with the results, try repeating the above process.
Step 5 - Bleach Pens
Bleach pens or grout and caulk repair pens are another option. They're easy to get hold of and provide a fuss-free solution. Simply press the pen along the caulk, leave for 10 minutes to set in and rinse with warm, clean water. Repeat as necessary and let the caulk dry naturally before allowing the area to get wet again.
Step 6 - Protection Against Further Staining
The correct application of caulk and using a mildew-resistant caulk during initial installation are the best methods in the prevention of mildew growth. However, adopting the following methods is also advisable to reduce the presence of this problem in your bathroom.
Clean the caulk regularly with a mold and mildew remover spray to stop the spread of mildew spores. Turn on the extractor fan or open a window whilst using the bathroom. Ventilation will reduce the humidity in your bathroom. Once you are finished showering or bathing, dry your tiles with a towel or cloth so that mold and mildew will have less moisture to thrive on.
     forum activity
