Tile Pool Deck Construction: 4 Tips
If you are considering doing your pool deck construction yourself here are a number of tips you may wish to consider to help you.
Tip 1 – Tile Surface
When you are choosing your tiles, consider the texture of the tiles carefully. You should look to install tiles that are non-slip, preferably with a gritted or heavily textured surface. This will be an important safety feature of your pool.
Tip 2 – Tile Material
If you live in an area where it is very hot, you should steer away from installing brick tiles. Brick easily crumbles and also retains the heat for a long period of time. This will make the tiles often too hot to walk on.
Tip 3 – Tile Shape
Square tiles are the most common form of tile found and also the easiest to install. If you are not very experienced at laying tiles, then you should probably opt for this type of tile.
Tip 4 – Budget
A good alternative to ceramic tiles are hardwood tiles. These are relatively inexpensive to buy and are hardwearing. They can be treated to give them a good weatherproof coating. This coating can also be renewed if the tiles become damaged. They are suitable for both indoor and outdoor pools.
