Tin vs Copper Tile Ceiling
Copper tile ceiling and tin tile ceiling share many of the same characteristics. They are both high quality substitutes for conventional ceiling materials. Metal ceiling tiles are more durable than drywall or wood. Both types of ceiling tiles offer similar benefits, and they are installed in similar ways. They only differ on a few variables.
Benefits of Metal Ceiling Tiles
Tin and copper tile ceilings are less likely to degrade into dust or deform from corrosion. They do not provide a food source for rodents or insects. Metal ceiling tiles are highly resistant to mold and discoloration. They also offer fire resistance. For example, tin ceiling tiles can withstand a fire hotter than 1300 degrees F for an hour.
Metal Ceiling Tile Installation
Tin and copper ceiling tiles are installed using the same process. Remove any crown molding. Measure the room, select a tile size, and lay out your design with a chalk line to determine how many regular and cut tiles you will need. Cut the tiles to fit as needed. Fasten them with furring strips, a drop ceiling grid, nails, or glue.
Differences in Ceiling Tiles
The only major differences in tin and copper ceiling tiles are price and availability. These are a result of local and global factors.
