Login Error
Close
Tips for Buying a Portable Air Conditioner and Heater Combo Unit
by DoItYourself Staff
Although finding an affordable portable air conditioner and heater combo unit is ideal, budget shouldn’t be the only factor to consider. You should also take into account factors such as brand, typical weather conditions in your area, and the various features each unit offers.
Choosing the Right Brand and Model
Portable air conditioner and heater combo units now have added functions to provide multipurpose use and in so doing, they become a better investment.
Newer models, for instance, also come with dehumidifiers. A dehumidifier helps reduce the humidity in the room. Reducing the humidity level will lessen the cause of bacteria buildup inside the house, such as mold and mildew.
Choosing the right brand is also just as important. Expect well-established brands to provide better and time-tested performance compared to those produced by new entrants in the market. Branded units are also more durable, being able to maintain optimal performance even in constant long periods of use. Generic brands, on the other hand, are rarely able to offer warranties or even guarantees for safety and service quality.
Consider the Climate in Your Area
Not all portable air conditioner and heater combo units are able to provide optimal service throughout the year. Some units, for instance, are incapable of working efficiently if it does not have the correct air temperature to draw from outside the house. Others may improve noticeably when they can rely on cool air from outside.
When shopping for portable A/C and heater units, always make sure that you inquire about the desired temperature levels for its operation and determine whether it would still be able to work well, considering weather conditions in your area.
Check If the BTU Level of the Unit is Right for Your Place
BTU is an acronym for British thermal unit, which is the standard measurement utilized for gauging the required amount of energy for producing and maintaining desired air temperature levels.
When shopping for portable A/C and heater combo units, check the BTU level and make sure that it is sufficient for the size of the site or room it would be installed in. If the BTU level is beyond what the location requires then you would be consuming more energy than you need, which also means having costlier utility bills.
There are, however, exceptions to the rule and which may apply in your case. If you expect the room to be constantly filled with people or exposed to sunlight or excessive cold then naturally, you require use of a portable unit that can offer a higher BTU level.
In any case, the guidelines below will help you determine the ideal BTU level you’d need from a portable air conditioner and heater combo unit.
  • 9,000 BTU units can cool a room with 200 square feet of space
  • 12,000 BTU units can cool a room with 400 square feet of space
  • 14,000 BTU units can cool a room with 550 square feet of space
Picking the Right Size of Unit for Your Room
Portable units also vary in size. A smaller unit generally uses less power compared to bigger units but they also require more time before they’re able to produce a sufficiently cool temperature for the room.
With these tips, you’re sure to find the best portable air conditioner and heater combo for your needs.
 forum activity
