Login Error
Close
Tips for Buying a Wireless Intercom System for Your Home
by DoItYourself Staff
A wireless intercom system may be a valuable means of communicating with people in your household. A bedridden family member can just push a button when calling a caregiver. For additional security, you can also talk to your visitors first at the front door before letting them come in. A wireless intercom system can also benefit small home businesses. There is no need for you to install an expensive home system to allow various departments in contacting each other. So what should you look for when buying a wireless intercom system for your home?
Voice Activation
Also known as VOX, voice activation allows you to use an intercom without pressing any button. This feature is ideal for children and the elderly who may find it confusing when using an intercom system.
Selective Call
Maintaining your privacy is important when it comes to choosing a wireless intercom system for your home. A selective call feature will allow you to privately communicate with somebody in the same house without fear of being heard. With this feature, each room usually has a station where you can speak to someone in private.
Digital Technology
Your wireless intercom system at home should use digital technology instead of analog. Intercoms that use analog technology are easily intercepted by other devices on the same channel. Since digital technology uses complicated codes, it will be not be easy for eavesdroppers to listen to your private conversations.
Handheld Wireless Monitors
Although many people use mobile phones to communicate from one end of the house to the other, using a wireless intercom system at home is another option for communicating with people in the same building. It has its own pros and cons but its advantages usually outweigh the disadvantages. A bedridden family member can just push a button when calling a caregiver. For additional security, you can also talk to your visitors first at the front door before letting them come in. So what should you look for when buying a wireless intercom system for your home?
Voice Activation
Selective Call
Digital Technology
Your wireless intercom system at home should use digital technology instead of analog. Intercoms that use analog technology are easily intercepted by other devices on the same channel. Since digital technology uses complicated codes, you will not have eavesdroppers listening  to your private conversations.
Have you failed to answer a doorbell ring because you were in the shower? A handheld and portable wireless monitor can help you speak to whoever is at the front door even if you are in the bathroom. Most of these wireless monitors in the market today have its own video so you can check to whom you are talking. Do not worry as these videos are only one-way and they won’t see you while you are in your bathrobe.
Easy to Install
Your wireless intercom system at home should be easy to install and re-install when you move. You do not need to have wireless intercoms that require a professional or technical support for installation.
Safe to Use
If you have a wireless intercom installed near your baby’s crib, make sure that it is made of safe and non-toxic parts.
Music Distribution
If you are into music played most of the time inside your house, you should look for wireless intercom systems that feature music distribution.
Coverage
Choose long range wireless intercoms for your home if you have a large property to cover or if you want to talk between buildings.
Power Source
Some wireless intercom systems are battery-powered while some are powered with an AC-DC converter. If you have solar panels at home, you can go for intercom systems powered by solar power so you can save on money and energy.
 forum activity
