Login Error
Close
Tips for Caulking Leaking Gutters
by DoItYourself Staff
what you'll need
  • * Silicone caulk
  • * Sandpaper
  • * Roofing cement
  • * Flashing
  • * Wire brushes
Leaking gutters require immediate attention.  If these are not fixed in a timely fashion there will be more troubles ahead; the exterior walls can be damaged and the original may worsen.  Here are some tips about caulking to fix leaky gutters.
Step 1 – Find the Cause of the Leak
The first few places to check for leaks are the gutter joints.  Next check the railings and the downspouts.
Step 2 – Clean the Leaky Area and Make it Dry
Use a wire brush to clean the problem area.  Dry it thoroughly and rub it with sandpaper. This method will help you clean of any old adhesive material that is no longer functioning properly.
Step 3 – Cover the Holes
If you find holes on the gutter, cover it with roofing cement. If the holes are big, use a combination of flashing and roofing cement.
Step 4 – Apply Silicone Caulk on Joints
If any old caulk still remains, you may use a wire brush and water to completely remove it.  Once it is cleaned and dried, you may apply beads of silicone caulking to it.
Step 5 – Attach the Joints
With the caulking already there, put the gutter back by reconnecting the joints.
 forum activity
