Login Error
Close
Tips for Choosing and Applying Basement Floor Paint
by DoItYourself Staff
Applying a basement floor paint is a great cost-effective alternative to wood floors or carpet and can turn your basement into a great space for an office, children's playroom, or lounge area. Outlined in this article are some great tips for choosing and applying basement floor paint.
Epoxy Basement Floor Paint
Though there are many different types of paint you can use on your basement floor, epoxy and concrete paints are the two most popular. Epoxy paint is a water-based paint that is extremely durable and very resistant to grease and oil. Additionally, epoxy paints are effective sealants to use in waterproofing your basement and are not difficult to clean.
Concrete Basement Floor Paint
Concrete paints are another viable option for waterproofing and are perfect if you are seeking a simplistic look for your basement since most concrete paints are grey. Like epoxy, concrete paints are also very durable.
Before you apply your basement floor paint you need to ensure the floor is not damp anywhere. If you find dampness anywhere make sure you dry it with a dehumidifier or hairdryer before application so the paint will hold to the floor correctly. It is also important to fix any cracks with caulking and use sandpaper to smooth out any rough areas. Finally before you begin painting, clean the floor thoroughly and remove stains. Use a roller to apply the paint in as many coats as you feel is necessary.
 forum activity
