Login Error
Close
Tips for Cleaning a CPU Heatsink
by DoItYourself Staff
Cleaning the CPU heatsink is absolutely necessary if you want to ensure the proper operation of your computer. Dirt and dust accumulates in the interior of your computer and can cause numerous problems to the processor, CPU, and cooling fans of the computer. The most important problem that might occur is overheating, since the CPU heatsink tends to overheat due to dust. Cleaning the inside of the computer is not a difficult task, but you need to be cautious so as to avoid damaging any computer parts. Here are some tips and hints on how to clean the CPU heatsink.
Assemble the Proper Tools
The first thing you need to do is to have all proper tools handy; keep in mind that you will need to open the computer box and remove certain parts, such as DVDs, CDs and more. You will need tools for fine tasks, but you should also make careful notes of the cables and plugs you have removed so that you don’t mess up the proper operation of your computer.
Use an Air Blower and the Proper Cleaning Products
The second thing you need to keep in mind is that cleaning the heat sink requires some cleaning products; don’t make the mistake to use cleaning products for your house because they can harm your computer. You can use certain types of alcohol, damp cloths and air blowers that will help you deal with the dust effectively. However, even with these safe products you need to be careful, because the heat sink might be caked with dirt and dust and will require additional effort to clean it properly and completely.
 forum activity
