Tips for Cutting Mortise and Tenon Joints
Cutting mortise and tenon joints can form part of the process of many a woodwork project, enabling you to create secure joins. In order to make sure that the joints are formed properly, it is important to utilize some tips during the process of cutting them.
Measure
Ensure that all the measurements you make are precise, which will ensure that the mortise and tenon joints fit together securely. Double check them before marking the wood and making any cuts. Continually check the measurements as you cut to ensure that you do not go too far.
Steps
Following the steps in the correct order will make cutting mortise and tenon joints easier. The peg component is known as the tenon and should be cut first, which will enable you to use this as a guide for the mortise section.
Equipment
Make sure that the tools that you use for the task of making mortise and tenon joints are appropriate. You are likely to find that manual tools are best for smaller sized joints, as they will often allow you to be more precise. Similarly, if you lack experience, it will be the easier option. For larger joints, power tool can be used to complete the task quicker, enabling you to finish with manual tools.
