Login Error
Close
Tips for Estimating Cedar Shingle Siding Cost
by DoItYourself Staff
If you are considering which options to use when replacing exterior surface coverings, it is a good idea to get an estimate of shingle siding cost. This will not only allow you to compare the cost to other options, but it will also be of assistance if you have a budget for the work.
Area
The first step that you will need to carry out when working out the shingle siding cost is to measure the area over which the siding will be laid. Make sure you take into account any overlapping that is required during the fitting procedure.
Quality
The quality of the siding will be a consideration when estimating the shingle siding cost as varying qualities come with varying costs. Think about the use the siding will be put to in order to determine the quality required.
Use
Think about where you intend to fit the siding in order to determine what type is required. Shingle siding is available in different grades, with each more appropriate for a specific purpose.
Labor
Factor in the cost of labor when estimating the shingle siding cost if you do not intend to do it yourself. Some installation methods are more labor intensive than others so will attract a higher fee.
 forum activity
