Login Error
Close
Tips for Fitting an Air Conditioner in a Basement Window
by DoItYourself Staff
When you need to install a window air conditioner into a basement window, it can often be a struggle to get the air conditioner to fit and rest securely in the window. Basement windows are commonly not as uniform as other home windows and can often be a problem when trying to fit with a standard size window air conditioner. Here are some tips that can help you this summer as you try to install your air conditioner and keep your basement cool.
Sealing Air Leaks
When installing an air conditioning unit in a basement window, you will oftentimes have to remove the window entirely to get the unit to fit securely. Removing the window will in most cases present a new problem of air leaks as small as a crack to several inches depending on the size of your window frame.
If there is a bit of space between the window frame and your unit, there are a couple of options. One is that you can place a couple boards underneath the unit so that it is resting on the outer sill. Using this method, you can tilt the air conditioner back slightly so that it drains properly outside and prevents rust formation. Another option is to fill the gaps on the side or top with Styrofoam or plywood or any other filler material that you have access to.
Securing the Air Conditioner
The most important thing when using a window air conditioner is that it is secure in place so that it will not be pushed in or out of the window. This is often the most difficult part about a window unit. If you will be shopping for a new unit, take measurements of your window before you go to the store. Either way, new or used, you may need to make a small shelf for the air conditioner to rest on. The shelf should have a slight slope as well so that the air conditioner drains outside. Even with a shelf, you may still have openings around the window. If this is the case, seal them with a small board taped into place. If you have a sliding window, use tape to create a seal along the sliding portion so that you can still open the window if wanted.
Securing Your Home
Once you install a window air conditioner unit, your window lock will no longer function properly. To maintain security in your home, you will want to cut a board or stick the length to fit between the upper window frame and the top of the sash. This will help to prevent unwanted intruders from prying open the window and entering your home.
Using these simple tips, you can easily install your air conditioning unit and have it working to its full efficiency this summer. Be sure to thoroughly seal all leaks and you will be on your way to a cool and energy efficient beat-the-heat summer.
 forum activity
