Tips for Getting a Strong Signal with an HDTV Converter Box
If you've recently purchased an HDTV converter box for your television and are unhappy with the signal you're receiving, you'll be pleased to learn that there are several simple ways to improve your converter box's reception. Below are the best tips for improving your HDTV converter box's signal.
Tip 1 - Add an Antenna
One of the most effective tips for stepping up your converter box's signal is to add an antenna to your HDTV setup. While an indoor antenna is liable to cost less, an outdoor antenna may do more to improve your signal, as it is not subjected to electrical interference from all the other appliances in your home. If you choose to go with an indoor antenna, keep in mind that you may need to play around with its positioning a bit before noticing a difference in signal quality. Even if you have an HDTV converter box, an antenna is essential to producing decent signal reception on a non-cable television.
Tip 2 - Add an Antenna Amplifier
If you find that an antenna isn't really doing the trick, you may want to try adding an amplifier, or "booster," to your antenna. These affordable devices can be easily attached to an existing antenna and help extend its signal reach, in addition to cutting back on static and fuzz that interfere with your picture.
