Login Error
Close
Tips for Increasing Diesel Engine Performance
by DoItYourself Staff
Maximizing diesel engine performance is an important goal in diesel vehicles. The diesel engines need care and proper tuning in order to enable output in the maximum range. This being the case, we need to make sure to understand at least five of the most important tuning methods available for improving the performance rate of the diesel engines. The following tricks and tips will enable you to take good care of your diesel engines in the best possible ways.
Tip Number One: Regular Upgrades
Perform periodic upgrading to the parts of the diesel engine. Installation of cold air intake systems will provide higher performance rates. In order to increase the combustion rate of the engine, install cold air intake system such that the air that flows into the engine is cooler than the air inside it. This process has been proved to increase the performance rate by more twenty percent at the minimum, along with very considerable improvement in the usage rate of diesel fuel by the engine.
Tip Number Two: Using Upgraded Diesel Fuel Injectors
Use upgraded diesel fuel injectors in the engine. By upgrading the injectors, we will be able to provide a higher range of power output for the engine. Also, the fuel consumption rate for such engines can be brought down by almost twenty percent. Performance injectors are designed in various models and are made to suit the capacity of different model engines. More than one hundred and fifty bhp power can be added if this is used.
Tip Number Three: Periodic Checkups
Periodic checkups for the diesel performance fuel systems will help significantly. The fuel system will require proper care and replacement as and when needed, in most cases. The engine is usually placed at least a distance of two feet below or ten feet away from the fuel system, which is known to have caused problems in the fuel injection delivery systems. If proper upgraded delivery system is fitted with the engine, the vehicle may receive increased horsepower fuel efficiency, along with low noise and smooth acceleration.
Tip Number Four: Replacing Modules
Replacing the diesel performance modules in the engine would provide better torque capacity of even thirty percent more than usual. Also, you will be able to get another one hundred and fifty horsepower by using this technique. You will not need to re-program the circuits by installing this.
Tip Number Five: Using Good Exhaust Systems
Good exhaust systems will be the best method to improve the performance of the diesel engines that we use. Smooth acceleration, low noise, effective usage of fuel and longer life for the engine will be the benefits given by this method. Temperature and pressure may be reduced in the system by choosing the right type of exhaust pipe.
 forum activity
