Tips for Installing a Kitchen Tile Backsplash Over Drywall
A kitchen tile backsplash adds lots of interest to a kitchen and is a quick, relatively simple do-it-yourself project when a few things are considered.
Check the Drywall
It is important to be sure the drywall is clean and free of water damage. If any water damage is present, remove the drywall and replace it with a waterproof material of equal thickness.
Cleaning
Choose glazed tiles because porous or unglazed tiles cannot be adequately cleaned and frequently will become stained from food residue.
Consider Cutting and Adhesives
Glass tiles, porcelain, and many speciality tiles cannot be cut with a regular tile cutter and often need special adhesives.
Spacing Lugs
Lugs are small extensions in the tile sides which establish a thin grout line when tiles are butted up against each other. If lug tiles cannot be purchased, a piece of cardboard works well in place of plastic spacers.
45 Degree Angles and Decorative Tiles
Off setting the tiles at a 45 degree angle can create an appealing effect which is not complicated for the few backsplash lines. In the same fashion, investigate purchasing decorative center tiles to be placed every so often. Though these tiles are often expensive, only a couple are needed to cover the small backsplash area and can add a lot of interest.
