Tips for Kitchen Countertop Edging
When installing kitchen countertop edging, it is imperative that some tips be followed in order to ensure lasting usability. Whether you are installing laminate or granite countertops, specific aspects of the edging installation must be addressed and solved.
Granite Edging: Install Last
If you are installing a granite countertop, the edging must be installed last. The granite countertop has to be secured to the base counter with mortar and has to hang over the edge an amount equal the width of the granite tiles that you are installing. This allows you to place the edging granite up underneath the actual countertop, preventing water from backing up underneath the tiles, as well as giving the entire area a clean, professional look.
Laminate Edging: Use Laminate Sealer
Laminate edging has to be installed in much the same way as granite except for the fact that a good laminate sealer needs to be used at the joints. Since laminate pieces are thinner than granite, the overhang that will be used is not enough to ensure that the water will not back up underneath the surface. A good laminate-based sealer will ensure that the joints join together without leaving room for water to work its way in.
Whether installing laminate or granite countertop edging, it is imperative that where the edging meets the actual countertop is watertight and has been sealed properly. If this is not done, water will get under the surface of the countertop and cause water damage, as well as allowing a breeding ground for mold spores.
