Tips for Regular Window Maintenance
As you go about your house care routine, do not overlook window maintenance. It is an important measure that will help to keep your windows in good condition and extend their longevity. Well maintained windows enhance the security and appearance of your home. Temperature fluctuations, rain, dust and debris all take their toll on windows. This contributes to a high wear and tear rate. Below are some regular maintenance tips.
Cleaning
Wooden windows can be wiped regularly with a damp cloth. This helps to remove dust and dirt. You want to avoid frequent washing with water, as it is likely to encourage rot due to contact with moisture. Vinyl and aluminum framed windows can be washed with a mild detergent and soft scrubbing brush. A glass cleaner helps leave your windows sparkling clean. Be sure to clean the window casing and the adjacent wall area as well. This helps to reduce build-up of dirt and debris in the window components, which often contribute to window jams.
Regular Inspection
It helps if you undertake a thorough inspection of your windows every season. Check the condition of the window frame and sash. Use a metal probe to look for signs of rot that could indicate moisture infiltration. The sun can cause certain areas of the frame to become brittle and warp. Paint may have peeled off in certain areas. Check for signs of moisture in double or triple-paned windows. This indicates that the seal has failed and has to be replaced. A failed seal reduces the insulation capacity of your windows. If you have weather stripping on your windows, check the condition during inspection. Make arrangements for replacement if the stripping has worn out. Check for any gaps between the window casing and wall. These can be filled with a latex caulk.
Sealing
Gaps around your window allow air to come in and encourage loss of warm air from within. This reduces the energy efficiency of your home. It also creates higher energy costs for you. Replace all worn out rubber seals. This helps to reduce air and water leaks. It also helps to secure the window in place. Use spray-form insulation or caulk to help you seal your windows.
Re-Painting
Wooden and metal window frames need to be re-painted every 3 to 4 years. It helps protect them from the elements and maintains their appearance. Always apply paint onto windows that have been well cleaned. Be careful not to paint over moving parts or a shut window, as the window will get stuck.
Damaged Parts
Cracks, holes and splinters in the window need to be attended to promptly. The longer you to take to address damaged areas, the more the window will deteriorate. Once you identify the rotted sections in wooden windows, use a screwdriver to clean out the bad wood. Fill cracks and holes in the window with epoxy putty. It is best to use several layers for better results. Once the putty dries, smooth the area with sandpaper then apply primer and paint. Cracked or broken glasses should be replaced promptly. It helps to secure your home and also prevents accidental cuts by the broken glass.
