Login Error
Close
Tips for Removing Paint from Wood Paneling
by DoItYourself Staff
If you need to remove paint from wood paneling there are a few things you should keep in mind as you perform this process.
Tip 1 - Clean First
The first thing that you will want to do is make sure that the area that you are removing paint from is clean. Many people do not think to do this because they are just removing the paint however, if you need to use sand paper or even a chemical paint stripper then you want both of those things to work effectively without causing any more harm to the area. You can do this with a wet rag and warm water or a wood cleaner followed by warm water depending on how dirty the area is.
Tip 2 - Try Sanding
Sanding is the number one way to get the paint off of wood paneling. You can either work with a hand held sander or just a piece of sandpaper. You may want to start with a just a piece and work with that especially if you are new to sanding. If there are several coats of paint you may want to use a stripper first and then sand off any of the remaining paint.
Tip 3 - Chemical Paint Stripper
Many people are against this idea because of the fumes but they now have more natural paint strippers that you can find that work just as well. All you have to do is apply the stripper to the area with the paint and wait the amount of time stated in the instructions. Then you can use a scraper to remove the paint and then wash off the area. If this does not work you can try again until you get all of it off or you can sand. If you do choose to sand as your next step you will want to make sure to first clean the area off completely and then let it dry so that the sand paper works effectively.
Tip 4 - Heat it Up
This is going to be one of your last options if sanding or chemical paint removers do not work. You will need to use a heat gun, however once you have heated up the area with the paint on it you can scrape off the softened paint pretty easily. You want to make sure though that you watch the surrounding wood while you are working with both the heat gun as well as the paint scraper so that you do not damage it.
Each of these tips together or separate can help to get the paint off of your wood paneling quickly and effectively.Make sure to let the area dry completely and sit for at least 24 to 48-hours before you treat or finish the paneling. Making sure to get all of the sand and dust or debris off will be the best way to get a smooth finish to your wood paneling and ensure you do not have to fix the job.
 forum activity
