Login Error
Close
Tips for Repairing a Leaky Toilet Cistern
by DoItYourself Staff
The toilet cistern contains all the working parts to help your toilet to perform properly. If they are properly maintained, they will last a long time. If you have a big family, then the toilet is one thing that will be used a lot. Things that are used a lot have a tendency to break down a little more often. When the toilet starts to leak, you are wasting water, so here are some tips to help you look for with a leaky toilet cistern
Tip 1 - Checking the Cistern
Check on the toilet cistern by taking the tank lid off and looking at the components inside. Flushing it a couple of times to be sure that things are working properly is not a bad idea. Some of the things to check would be the flush valve and the fill valve. If the valves are not working right, that will cause the toilet to continually run.
Tip 2 - Adjustments
Try to adjust the valves to see if that fixes the problem, before you go out and buy a kit to fix the cistern. If the float in your tank has a ball on the end of a rod, try to lift it and listen to the water. If the water stops, all you may have to do is adjust the float. To adjust the float, you can bend it slightly in the middle. You will need to be gentle, because you will be putting pressure on the valve. There may be adjustment screws attached to the rod that can be used to adjust the float also. Now try to flush the toilet and see if that fixed it.
Tip 3 - Shutting the Water Off
If you have to go beyond the second tip, that means you may have to shut the water off to the toilet. The toilet should have a shut off valve under it. If not, you will have to shut off the main water valve to the house.
Tip 4 - Checking the Washer
Check the washer on the fill valve in the toilet cistern. You may have to remove a few screws, to take off the cap to the fill valve, to check the washer. Once you have the cap off, you can check the condition of the washer. Check for cracks or if it is broken, and if it is, replace it. Once it is all back together, turn the water back on and flush the toilet.
A leaky toilet is no fun, so keeping it up is a good idea. You can save yourself some money by keeping an eye on the cistern. If you hear water running, you may have a leaky valve. These are easy fixes that will help the toilet run longer without having to call a plumber. These are some great money saving tips that the whole family can take advantage of and learn how to do. This will help to avoid the irritating noise of water running in the toilet cistern and keep the whole family happy.
 forum activity
