Tips for the Upkeep of Tumbled Marble Tile
Tumbled marble tile is a beautiful addition to any home or building. You will find tumbled marble tile in bathrooms and kitchens. There are many uses for tumbled marble tile because they stand up to a lot of abuse. There are several things you can do to maintain your tumbled marble tile.
Do not Use Acid
Marble is unbalanced chemically which makes it fragile and easy to scratch and mark. Cleaning tumbled marble tile should never involve cleaning materials that contain acid. Using acidic cleaners can cause the tumbled marble tile to become gouged and pitted.
Seal Regularly
Marble is a great material that is incredibly absorbent. This means that stains, marks and grime can easily set in the tumbled marble tile. You can prevent this from happening by sealing the tumbled marble tile with any number of products. You should seal the tile again every 6 months to ensure its versatility.
Simple Cleaners
Sometimes the best cleaners are the simplest. Use organic cleaners on tumbled marble tile. Soap, water and a sponge is all that you need to clean and maintain the tile. Harsher chemicals can easily scratch the surface of the tumbled marble tile.
