Login Error
Close
Tips for Unclogging a Blocked Sink
by DoItYourself Staff
One of the most annoying problems with any home is the blocked sink. This can cause minor annoyance, or you may find yourself up to your knees in dirty water, desperately trying to unplug the sink with a plunger. Using a plunger like this is one of the ways in which you can get rid of any clog, but there are also a number of other methods which might solve your problem just as quickly. If you are having a problem with a blocked sink, then you need to get it sorted out fast, without having to go to the expense of paying for a plumber.
Use a Drain Cleaner
There are a number of liquid products on the market which promise to try and unclog your drain without needing any effort on your part. They can be simply poured down the drain, and chemicals in the product them shift the grease which is causing the problem. These kinds of solutions are fine if this is the first time you have had this problem, or if it is a rare occurrence, but if the sink really is blocked, then you may have difficulty getting rid of the blockage using only drain cleaning chemicals.
Use a Drain Snake
This depends very much upon where the blockage in your drain is. If you find that your drain is blocked underneath the earth, so that you can't remove the pipes and work on them, then it is worth buying or renting a drain snake. These are electrical devices which are pushed into the drain. Turn on the power, and the drain snake removes blockages. This is a good solution to this problem, and will usually enable you to get rid of a blocked drain for good.
Remove the Drain Trap
One of the most common causes of drain pipe problems is a blockage in the drain trap. These parts of the drain, sometimes known as an S or P trap, curve sharply, and make a perfect place for grease, mold and limescale. You can get rid of these problems by taking off the trap. Simply drain the sink of as much water as possible,  and then spread out towels around the area of the pipe. You're going to get wet, but it is worth it to get rid of the dirt. Drain as much of the pipe into a bowl as you can, and then wash it thoroughly in soapy water. This will help you to remove the blockage from the trap area.
Use a Plunger
If the problem is close to the sink itself, then you may have to resort to the plunger. This is not a very elegant or convenient way of working, but it gets the job done. Place the plunger over the drain hole in the sink, forming a tight seal, and then move the plunger up and down until the water is freed. You may need to do this several times before the water fully drains.
 forum activity
