Login Error
Close
Tips for Using Textured Ceiling Paint Properly
by DoItYourself Staff
The home decorators would definitely benefit from textured ceiling paint tips. Here are some things to remember for this task:
Getting Things In Order To Paint
When preparing to do a textured ceiling paint job it is important to have a room in order before starting the job. Make sure to remove the furniture from any room that you plan to paint. Covering the furniture will also do the trick and don't forget to cover the floor as well.
Protection From The Paint
Before starting the job it is a good idea to wear googles to protect the eyes. Also a hair net is needed to prevent paint from spilling on the head and wear a mask to limit the fume intake.
Preparing The Paint
Texture paint should be placed in a roller pan. These paints can range from smooth to rigid. Saturate the paint roller by dipping a roller into the pan.
Painting The Ceiling
Be sure to paint a four-foot by four-foot area on the ceiling by using a thin coat. Use this process over the whole ceiling. Use a second coat and an additional coat may be added if the paint is too thin. Let it dry and in the morning the job will be complete.
 forum activity
